I am trying to fit about 160 minutes of DVD quality PAL AVI that was recorded in HDTV. I tried using Digital Media Converter and the results are somewhats pixelated and I can only fit 80 minutes of footage on one DVD. Is there a way to maintain quality and what is approximentaly the best bitrate for this type of length for TMPGE considering that Digital Media Converter does not allow you to change the bitrate?
www.videohelp.com/calc and calculate the bitrate or use just the wizard in tmpgenc.
Or use an all-in-one tool like diko or thefilmmachine or avi2dvd. They support pal to ntsc also.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
Cant convert Pal .AVI to NTSC DVD in Avidemux
By Hittz in forum Video ConversionReplies: 6Last Post: 5th Nov 2009, 08:43 -
NTSC(?) avi to PAL dvd
By Instant Martian in forum Video ConversionReplies: 34Last Post: 14th Mar 2009, 16:32 -
Can AutoGK convert PAL Region 3 dvd to NTSC .avi?
By bloomcounty in forum Video ConversionReplies: 14Last Post: 20th Nov 2008, 20:31 -
Best point at which to Convert?? (NTSC AVI to PAL DVD)
By junk in forum Video ConversionReplies: 3Last Post: 28th Jun 2007, 17:15
