    Oct 2003
    Canada
    O.K. so I ripped an unprotected DVD to my HD with DVD Decrypter.
    How can I import the files into Pinnacle Studio 9 so I can copy the clips I want?
    Thanks again boys and girls
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    If in doubt, Google it.
    Oct 2003
    Canada
    Originally Posted by jimmalenko
    O.K. I followed step by step instructions for DVD Decrypter. I get a video track but no audio.
    help please.
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    3. Select Demux, you must select each video and audio and select Demux for all separate
    You have to tick each stream you want, then click "demux" for each stream individually.
    Oct 2003
    Canada
    O.K. just followed that step by step again. I got a video file, and an audio file. But they won't play together.
    Also these files will not load into Pinnacle Studio.
    So.... I d'loaded Rejig
    Same problem. Movie won't play with any audio. But I can now load video file into Pinnacle. So we are getting closer!
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Sounds like Pinnacle cannot accept elementary streams. Junk !
    Mux the audio and video back to an MPEG file and then try loading that.
    Oct 2003
    Canada
    And how do I do that?
