I used all of the above over the weekend to crearte a disc with multiple chapters from mutliple titles and it worked perfectly following the directions found at http://members.dodo.net.au/~jimmalenko/test.htm. Tonight, I tried it (at least 5 times using different data) and when I open DVDShrink just to view the finished product, I get:
DVD Shrink encountered an error and cannot continue.
Invalid datat in file "E:\VIDEO_TS\VTS_01_1.VOB
Also, when I try to open it with WinDVD, I get:
The file number 1 has an invalid format.
I ran IFOEdit on an unmerged VOB and it came out just fine and DVDShrink was able to play it. Is there some issue with VOBEdit that I am not aware of? I followed the directions very carefully each time.
Here is the datd I used:
VOBEdit
VTS_01_001.VOB, VTS_01_002.VOB --> VTS_01_1.VOB
IFOEdit
VTS_01_1.VOB --> VIDEO_TS.BUP, VIDEO_TS.IFO, VTS_01_0.BUP, VTS_01_0.IFO
Any help available?
Thanks - Rich
Closed Thread
I think you'll find that the one drawback of that method is that the VOBs you're joining need to have the exact same settings - subtitles, audio streams, Aspect Ratio, Format etc etc, for that method to work properly.
You may like to try something like TMPGEnc DVD AUthor, which should handle multiple sources with different characteristics a lot better.If in doubt, Google it.
Don't double post.
https://www.videohelp.com/forum/viewtopic.php?t=281787Want my help? Ask here! (not via PM!)
demuxing VOBs with VobEdit
By siluet in forum Newbie / General discussionsReplies: 13Last Post: 22nd Nov 2012, 17:57 -
VobEdit - won't join vobs
By bahjan in forum Authoring (DVD)Replies: 4Last Post: 6th Feb 2012, 20:29 -
Cannot get VobEdit to work
By Ramon in forum Newbie / General discussionsReplies: 8Last Post: 4th Sep 2011, 10:13 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 20:33 -
VOB demuxer: PGCDemux or VOBEdit ?
By gabier in forum Video ConversionReplies: 4Last Post: 2nd Dec 2007, 10:01
