Why does userimages.bmp get copied to any directory where a disc image is opened with Nero 7? Anyone else run into this?
I have the exact same situation, i havent figured out why yet though.
i will keep you posted -
http://www.flexbeta.net/forums/index.php?showtopic=8094&mode=linearplus
Two people there say they don't get it.If in doubt, Google it. -
Well, I stopped using Nero 7. Went back to 6. I think 6 is so much better. But try uninstalling Nero 7. Good luck with your file associations. I formatted my hard drive anyway ... so, I'm not going anywhere near Nero 7. I think 6 was just fine.
I get it with version 7.0.1.4b. Rather annoying that they didn't fix it with this release. I was going nuts thinking I had some kind of new virus until I found some threads on the net about it.
According to this post on cdfreaks you can do the following to specify a different location of the annoying file. Not a fix, but at least it makes it less annoying.
LINK
nero has a registry entry:
HKEY_CURRENT_USER\Software\ahead\Nero - Burning ROM\Settings\WorkingDir
this seems to be the issue over here
to get it out of my way I created a temp dir in the nero installation folder and changed the registry entry for the entry above to:
C:\Program Files\Nero\Nero 7\Temp
Extracting BMP's from a HDV
By alegator in forum Video ConversionReplies: 3Last Post: 18th Jan 2008, 20:20 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 22:09 -
Nero 6, mpeg4 & dvd-plug in
By dll in forum Newbie / General discussionsReplies: 0Last Post: 10th Nov 2007, 11:05 -
nero 8 & dvd shrink
By jerbevpicasso in forum Newbie / General discussionsReplies: 17Last Post: 24th Oct 2007, 22:36
