i will explain
each weekend, i have to film 2 rugby matches for my club.
i need to do 3 copies of each at least, so 6 dvds to copy, sometimes more.
so i will use direct copying from my video camera (dv input) to DVR recorder to make master dvds rapidly and do dvd copies with my computer.
so why a dvd recorder with a hdd ?
it's for recording rugby matches on TV and edit them (tries compilation for example)
the only solution i see is to copy hdd contents on a dvr-rw
and edit them on pc with appropriate softwares.
my dream was to transfert directly mpeg2 to pc for editing
it's not possible![]()
Results 31 to 37 of 37
Originally Posted by donpedro
I believe that if you buy recorder that records to DVD-RAM (or HDD and then to DVD-RAM), you can just copy files that are on it and rename extension to mpg and you have your mpeg2 file. Does it make it more simple for you ?
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
Originally Posted by lolivePinnacle Studio 8 and DV home video editing (ver.9 already home)
one more time i think you're right don pedro
So i have not the choice and i can find dvd recorders less expensive than the Toshiba/Panasonic with ethernet.
but
i never used a dvd-ram
i'm going to look after informations about it
merci -
Pioneer's PRV-LX1 comes close to your description for features but it sells for over $4,000. http://www.pioneerelectronics.com/pna/product/detail/0,,2076_204147818_38303,00.html
The Pioneer DVR-533H-S and 633H-S can record your DV sources, can record from the broadcast programs to hard drive for cutting segments, and can make fast exact duplicates of existing burned DVDs all without using a computer. -
hum hum
4.000$ is a little bit expensivefor me
so the model DVR-533H-S is enough for me
merci frobozz
Seagate Expansion 2.0 TB USB 2.0 Desktop External Hard Drive
By kyrcy in forum ComputerReplies: 7Last Post: 30th Nov 2011, 12:03 -
Ethernet / USB / WDTV questions..
By rucanunes in forum Media Center PC / MediaCentersReplies: 1Last Post: 10th Mar 2010, 11:06 -
Need advice for buying a desktop DVD recorder.
By Xandaum in forum DVD & Blu-ray RecordersReplies: 9Last Post: 24th Jul 2007, 10:16 -
HDD Recorder with USB and Ethernet ports, that also plays DivX files?
By Dr_trout in forum DVD & Blu-ray RecordersReplies: 4Last Post: 20th Jul 2007, 13:59 -
Can Anyone Recomend a DVD Recorder DeskTop with a Hard drive?
By scustalow in forum DVD & Blu-ray RecordersReplies: 4Last Post: 24th May 2007, 07:08
