When using the DVD-RB Pro how do you get around having to to hit Encode for each part of the files? I locked the 1 Click mode, but, when it kicks into the Encoding part of all the files I have to set there & hit the Encode tab allllll the way through the whole dam dvd.
THANKS..
Results 1 to 10 of 10
Mine is automated.
winifreid
Don't think mine is showing just a "backup dvd" tab, im about 50% of CLICKING through a dvd now, but it looks like theirs 4 different tabs but 3 are to darked out to read right now. Thanks
bacardi/avt
Can't check to see if that is or is'nt on, will look after the fun im having now though.. Thanks -
If you see 3 buttons, then it isn't in one clcik mode. There has to be a check beside it.
I'm very sure I placed one.. see, it did this last night also, using the 1 click mode.
@noslow, after you start Rebuilder, click the mode button and then scroll down to the spot which is labeled 'One Click' just highlight that and that should set you up as a one click automated rebuilder program. Beyond that just confirm that CCE is were it should be, which is pretty much asked when you are installing Rebuilder at the beginning.
MovieDud -
Originally Posted by bacardi/avt
It seems in the "Special Settings" on the "Run Encoders Mininized" having a check there fixed the automated problem for me. Now just to figure all the best tweaks . Thanks alot all.
PS. This ware kicks ass!
DVD Ripping...DVDShrink, DVD Fab question...
By nharikrishna in forum DVD RippingReplies: 9Last Post: 28th Feb 2011, 05:08 -
Regional Code Question - Insignia DVD player - can't play DVD I ordered..
By LadyDriver22 in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2010, 12:08 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43 -
question about difference between TMPGEnc DVD Author and DVD Flick
By jimdagys in forum Authoring (DVD)Replies: 1Last Post: 23rd Apr 2008, 20:06 -
question about multiple titles on DVD using DVD Flick
By jimdagys in forum Newbie / General discussionsReplies: 1Last Post: 4th Mar 2008, 20:47
