Burning a SVCD with VCDEasy: When I run VCDEasy with the CDRDAO option selected, I get this error:
C:\WINDOWS\system32\WnAspi32.dll" not found. This Aspi layer (required by CDRDAO) may be missing or not be installed correctly. CDRDAO support is disabled.
Other posts suggest running ForceASPI. I downloaded and went to install, but it is not supported in XP. Help! What do I do?
I had the exact same problem, but i found a sollution with new and updated files.. E-mail me and i will mail you the files..
Best Regards A.m
the-beast@telia.com
Colors Error!!! Have fix??
By Cauptain in forum RestorationReplies: 4Last Post: 19th Jul 2011, 09:37 -
How to fix avidemux error when h.264 is used
By skorpinok in forum Video ConversionReplies: 0Last Post: 15th Jul 2011, 10:00 -
musicmatch error message fix
By deanst2 in forum ComputerReplies: 0Last Post: 19th Oct 2009, 17:54 -
FAVC - Error (Fix VTS Sectors failed!)
By tim_ver in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2009, 01:16 -
Newbie assistance. GMC error - how do I fix it?
By JesterDev in forum Video ConversionReplies: 3Last Post: 10th Oct 2008, 12:23
