Hi,
Captured a couple of old Beta home movies using the following steup: a Sony SuperBeta Hifi VCR model # SL-HF1000 (top of the line in its time) connect to a Sony DCR-PC330 digital camera which is then connected to a Sony Vaio PCV-RZ46G via an I-Link cable. Used WinDV to capture to the PC in Type-2 AVI.
This setup worked flawlessly with zero missing frames all the time.
However, as a first time beginner, I have so many questions. But I'll refrain myself and I'll ask just a couple:
(1) the quality of the digital output shows a redish hue throughout which it does not exist in the original analog tapes. I wonder if there is anything I can do to prevent that from happening or whether I can use VirtualDUB (for instance) to fix that.
(2) I used VirtualDUB to split one of the AVI files into two using CUT/DELETE and rewrite the resulting file onto another AVI file. The result introduced a number of defects in both video and audio. I wonder if there are any parameters that must be adjusted before using VirtualDUB even for a semmingly simple task as this.
(3) Is there a VirtualDUB user guide that explains all the myriad of parameters setup?
I'd appreciate very much any help.
Thanks,
Armando
The reddish hue is quite possibly mismanaged color by the DV hardware or the DV software decoders on your computer.
Restoring Bad Video Tapes
By rajakumarr19 in forum RestorationReplies: 33Last Post: 25th May 2012, 02:46 -
Trying to play old Beta tapes
By razielle in forum RestorationReplies: 10Last Post: 6th May 2010, 09:54 -
Restoring VHS tapes with a mix of NTSC and PAL-M encodings?
By leon43 in forum RestorationReplies: 5Last Post: 24th Nov 2008, 05:31 -
Beta/VHS Video Restoring tools. Is this a proper setup?
By HOTPROPHET in forum Newbie / General discussionsReplies: 0Last Post: 18th May 2008, 00:48 -
Questions on converting Beta tapes to DVD and quality
By rbatty11 in forum Video ConversionReplies: 7Last Post: 30th Apr 2008, 15:54
