Hi,
Thought I'd post this in here. I was burning a DVD yesterday with DVD Decrypter and it was working fine, then, I went to burn another DVD, and I recieved the following I/O Error.
I then tried burning a DVD with NERO and I recieved the following error message.I/O Error!
Device: [2:0:0] HL-DT-ST DVDRAM GMA-4020B (D: ) (ATA)
ScsiStatus 0x02
Interpretation: Check Condition
CDB: 2A 00 00 00 04 20 00 00 20 00
Interpretation: Write (10) - Sectors: 1056 - 1087
Sense Area: 70 00 02 00 00 00 00 0A 00 00 00 00 30 05 00 00 00 00
Interpretation: Cannot Write Medium - Incompatible Format
Here is the full log from NERO.Track following error
Could not perform end of Disc-at-once
Burn process failed at 2x (2,770 KB/s)
After wasting like 3-4 DVD-R's, I contacted Gateway support and they told me to try a different brand of DVD-R's, then if it doesn't work, let them know so they can send me a new DVD drive.Ali Khan
None
1A23-XXXX-XXXX-XXXX-XXXX-XXXX
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 6:35:34 PM
Nero Version: 6.6.0.8 (Nero Express)
Recorder: <HL-DT-ST DVDRAM GMA-4020B>Version: A105 - HA 3 TA 0 - 6.6.0.8
Adapter driver: <atapi> HA 3
Drive buffer : 1312kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <HL-DT-ST DVDRAM GMA-4020B>Version: A105 - HA 3 TA 0 - 6.6.0.8
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD1600JB-53EVA0 atapi Port 0 ID 0 DMA: Off
CdRomPeripheral : HL-DT-ST DVDRAM GMA-4020B atapi Port 3 ID 0 DMA: On
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GMA-4020 D: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 510MB (522988kB)
Free physical memory: 93MB (95844kB)
Memory in use : 81 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
10.10.2005
UDF/ISO compilation
7:23:24 AM #1 Phase 112 File dlgbrnst.cpp, Line 1832
DVD-Video files reallocation started
7:23:24 AM #2 Phase 114 File dlgbrnst.cpp, Line 1832
DVD-Video files reallocation completed (no file modified)
7:23:24 AM #3 Text 0 File Isodoc.cpp, Line 6172
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet :FALSE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
7:23:24 AM #4 Phase 111 File dlgbrnst.cpp, Line 1832
DVD-Video files sorted
7:23:24 AM #5 Text 0 File Reader.cpp, Line 127
Reader running
7:23:24 AM #6 Text 0 File Writer.cpp, Line 122
Writer HL-DT-ST DVDRAM GMA-4020B running
7:23:24 AM #7 ISO9660GEN -11 File geniso.cpp, Line 3293
First writeable address = 0 (0x00000000)
7:23:24 AM #8 ISO9660GEN -11 File geniso.cpp, Line 3293
7:23:24 AM #9 Text 0 File Burncd.cpp, Line 3153
Turn on Disc-At-Once, using DVD media
7:23:24 AM #10 Text 0 File DlgWaitCD.cpp, Line 259
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2276911 (505:58.61, 4447MB)
7:23:24 AM #11 Text 0 File DlgWaitCD.cpp, Line 271
Write in overburning mode: NO (enabled: CD)
7:23:24 AM #12 Text 0 File DlgWaitCD.cpp, Line 2316
Recorder: HL-DT-ST DVDRAM GMA-4020B, Media type: DVD-R
Disc Manufacturer: RITEKG - 04
Disc Application Code: 64, Disc Physical Code: 193
7:23:24 AM #13 Text 0 File DlgWaitCD.cpp, Line 433
>>> Protocol of DlgWaitCD activities: <<<
7:23:24 AM #14 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2276912 (2276912) = #2276912/505:58.62
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2276912 blocks [HL-DT-ST DVDRAM GMA-4020B]
7:23:24 AM #15 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [HL-DT-ST DVDRAM GMA-4020B] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4663115776, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2276912 | lead-out | 1 | 0x41 | 0x00
7:23:24 AM #16 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
7:23:24 AM #17 Text 0 File Burncd.cpp, Line 4040
Cache writing successful.
7:23:24 AM #18 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
7:23:24 AM #19 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 2x (2,770 KB/s)
7:23:24 AM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
7:23:24 AM #21 Text 0 File DVDR.cpp, Line 2194
Recording mode: Sequential Recording Mode
7:23:24 AM #22 Text 0 File Mmc.cpp, Line 21235
Set BUFE: Buffer underrun protection -> ON
7:23:24 AM #23 Text 0 File DVDR.cpp, Line 2340
Start write address at LBA 0
DVD high compatibility mode: Yes
7:23:24 AM #24 Text 0 File Cdrdrv.cpp, Line 8430
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 2FE10 h
Start sector number of the next Border-In: 2FFA0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
7:23:58 AM #25 Text 0 File Cdrdrv.cpp, Line 1287
07:23:58.718 - HL-DT-ST DVDRAM GMA-4020B\H3 T0 : Queue again later
7:24:48 AM #26 SCSI -1119 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 3, TA 0, LUN 0, buffer 0x09BB0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x09
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x10 0xE0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x04 0x00 0x00 0x00 0x00 0x10
0x32 0x27 0x04 0x0C 0x09 0x00
7:24:48 AM #27 CDR -1119 File Writer.cpp, Line 311
7:24:48 AM #28 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
7:24:48 AM #29 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
7:24:49 AM #30 Text 0 File DVDR.cpp, Line 2603
EndDAO: Last written address was 4319
7:24:49 AM #31 CDR -1119 File WriterStatus.cpp, Line 167
7:24:49 AM #32 TRANSFER -24 File WriterStatus.cpp, Line 167
7:24:49 AM #33 Phase 38 File dlgbrnst.cpp, Line 1832
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 3/11/2005 6:28:09 PM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 8/4/2004 1:59:42 AM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
I use Ridata (Ritek) branded DVD-R's and they have been working fine for the past few months now without any problems. This just happened yesterday. I searched around but couldn't find any information on how to fix this. Also, here is the info from NERO about my DVDRAM.
Any help would be appreciatedNero InfoTool 3.00
Drive Information
Drive : HL-DT-ST DVDRAM GMA-4020B
Type : DVD-RAM Recorder
Firmware Version : A105
Buffer Size : 1312 KB
Date : ?
Serial Number
Vendor Specific :
Drive Letter : D:\
Mechanism : Tray
Read Speed : 32 X
Write Speed : 12 X
Read CD Text : Yes
Return C2 Pointers : Yes
Read CD-R : Yes
Read CD-RW : Yes
Read DVD-ROM : Yes
Read DVD-RAM : Yes
Read DVD-R : Yes
Read DVD-RW : Yes
Read DVD+R : No
Read DVD+RW : No
Read DVD+R DL : No
Read BD-ROM : No
Read BD-R : No
Read BD-RE : No
Read Digital Audio : Yes
Read CD+G : No
Read VideoCD : Yes
Write CD-R : Yes
Write CD-RW : Yes
Write DVD-R : Yes
Write DVD-RW : Yes
Write DVD-R DL : No
Write DVD+R : No
Write DVD+RW : No
Write DVD+R DL : No
Write DVD-RAM : Yes
Write BD-R : No
Write BD-RE : No
Buffer Underrun Protection : Yes
Mount Rainier : No. I will try the different media and let you know what happens. Also, an important point.
THE DVDRAM CAN STILL BURN CD's WITHOUT A PROBLEM
Sorry for the bold and caps but some people might miss it. Once again, I appreciated the help.
LiVe iS juSt EvIl SpElLed BAcKwArDS!
DVD Laser may be shot sInce it still burns CDs.They die wothout the least hint. I also have a gateway that came with a DVD/Ram drive. The same exact thing happened to me. Replaced with $70 NEC 3500 from Newegg and been happily burning backups since then.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
Yep, I talked to Gateway and they're sending me a new DRIVE. YAY
Enchanted error (DVD Decrypter)
By rickygg in forum DVD RippingReplies: 1Last Post: 4th Apr 2008, 09:39 -
DVD Decrypter error
By turbochargedRS in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2008, 19:08 -
i/o error in DVD Decrypter
By msdker in forum Newbie / General discussionsReplies: 18Last Post: 20th Dec 2007, 22:03 -
DVD Decrypter error
By tRAVALO in forum DVD & Blu-ray WritersReplies: 6Last Post: 26th Aug 2007, 11:10 -
Error with DVD Decrypter...
By hiimbored in forum DVD RippingReplies: 29Last Post: 4th May 2007, 20:37
