I borrowed my daugher's video DVD of her wedding in order to make a copy for myself.
The wedding was in Ireland and the DVD was made there by a video service.
I tried to make a duplicate disk using Veritas "Record Now" and Roxio "Disk Copier" and
could not complete the operation with either application. I then tried copying to my
hard drive with the same result. After over 90% "progress," the operation would stall.
I inspected the DVD for damage and found none. I cleaned the DVD.
I displayed the contents of the DVD and found that there were several files. I copied
them to my hard drive one file at a time and that worked with most of them but the
last one would not copy but hung up like the entire DVD had.
Apparently, this one file (with a VOB extension) was causing all the problems.
The file is NO. 4 of 4 VOB files in the Video_TS folder. When I play the final portion of the video on the computer, there are frequent pauses or interruptions. However, the video plays fine on the DVD player hooked up to the TV.
What can I do to dupe this problem file?
Try ripping it with DVD Decrypter, in ISO mode. Then burn the ISO image with your software.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
You could also try isobuster if you find that DVD Decrypter can't salvage the files.
Read my blog here.
Try iso buster if it didn't work try using dvd shrink edit feature to cut out that part. Must have a weak burn at that location maybe cheap media, it plays but can't copy. You could also try other programs and dvdroms to see if it can be read.
I found a sure fire way to get data off of damaged or scratched cd's and dvd's. Maybe this will help you as well, its worth a try. Its called DVD DATA RESCUE.
If at first you don't succeed; call it version 1.0 -
i bet it's that new scheme they've been working on for consumers to copy-protect thier own wedding videos.
I am just a worthless liar,
I am just an imbecil
HELP! Convert new file to work on old server.
By NP1975 in forum Video ConversionReplies: 4Last Post: 15th Feb 2011, 18:52 -
Some movies are stubborn lately
By dougworm in forum DVD RippingReplies: 2Last Post: 25th Dec 2009, 02:40 -
Stubborn AVI files arent working!
By miiitchhh in forum Newbie / General discussionsReplies: 3Last Post: 5th Apr 2009, 23:11 -
Looking for some help removing stubborn Trojans
By RKelly in forum ComputerReplies: 14Last Post: 12th Oct 2008, 18:46 -
Divx problems......how do I fix a "stubborn" file?
By Hank Kinsley in forum Newbie / General discussionsReplies: 5Last Post: 3rd Sep 2008, 20:34
