well its been a while but i need some help again, I have a couple of MPEG2 files I want to put on DVD with a simple menu,but after authoring with Nerovision express I have been unable to play on any of my 3 dvd players?(plays ok on the pc under media player) The MPEGS are both over 2gig,(2.15 & 2.18) and when i was using Nerovision an error message came up stating the dvd may only be playable under windows?
is there a way i can author a dvd image and then shrink using DVDshrink to fit the project onto one dvd-r? I have tried only using 1 MPEG and only using 1 disc per file but had the same problem? is the 2gig+ file a problem?I have used Nerovision before to create all my home dvd's and I use Vegas to capture and edit to MPEG2 with no problems. I am about to download TMPGEnc DVD Author and give that a go! Hope one of you guys can give me some ideas??![]()
Burn Baby Burn!
Hey I downloaded TMPGEnc DVD Author and have found it a great program! I was able to put my 2 MPEG2 files together into one ISO image and then play around with them in DVDshrink. Now I just have to burn to DVD!
This is exactly what I have been trying to do. Anyone out there struggling with Nerovision Express I would strongly suggest you give TMPGEnc DVD a go!!Burn Baby Burn!
NeroVision Express 3 does not have chapter buttons
By Brent G. in forum Authoring (DVD)Replies: 1Last Post: 8th Aug 2008, 23:45 -
DVD-RW VRO to DVD in NeroVision Express problem
By ecc in forum DVD RippingReplies: 1Last Post: 30th Jul 2008, 00:17 -
Is somebody a NeroVision Express expert?
By jeanpave in forum Authoring (DVD)Replies: 12Last Post: 15th Sep 2007, 22:42 -
NeroVision Express 3SE: Return to the main menu?
By frankieg in forum Authoring (DVD)Replies: 2Last Post: 11th Jul 2007, 10:31 -
main menu music, nerovision express 3
By Reggie6966 in forum Authoring (DVD)Replies: 4Last Post: 10th Jun 2007, 07:00
