hello guys
I have a dvd i wanna make a copy of it
so i don'T waste my original
I tryed dvdshrink.....
but this time im pretty messed up
i can't compress it
audio seems to be 250megs or something & video to the lowest 67.9% something can'T rip it won'T fit a normal dvd
what are the solution
i know many does it
it's possible but what soft do i need?
thanks!!!
The main software you need is grammer version 1, and search version 2.5.
You might also consider basic physics 101, where you learn that something big won't fit into something a lot smaller unless you sqeeze it. Video is the same.
A final hint - if you don't like what shrink is doing after you have read the guides and spent some time with it, add DVD Rebuilder to your search.Read my blog here.
run shrink 2 times?
i don't get it?
Cause i know many uses dvd shrink to make them & they come out well.
But i don't know how to make it for that particular dvd it seems it won't let me even with analysis
ill retry -
Use DVD-RB instead.
Drop to HALF D1 resolution tooWant my help? Ask here! (not via PM!)
Ok, seriously, you simply cannot shrink a dvd9 into a dvd5 without compressing it. It is basically a 2 to1 compression so the fact that it is only about the mid 60% is really pretty good already. Will have to do this my friend. Choose only the movie, omit ALL audio tyracks you do not need. In other words just one 5:1 english or whatever language you prefer. That's it!
Now you may not even need compression or alt least, not as much. Use both analysis and other quality settings. These will NOT INCREASE quality. You cannot ever do that. It will diminish the loss of quality you will experience.
Once you are ready to backup, choose create ISO and burn with decrypter. Get your self DVD decrypter to burn the resulting ISO file to a full working DVD.No DVD can withstand the power of DVDShrink along with AnyDVD!
Rip DVD-R's, edit out commercials, burn new DVD Dual Layer...software?
By ruehl84 in forum Authoring (DVD)Replies: 5Last Post: 23rd Feb 2012, 03:06 -
Dual Layer DVD successfully burned, but won't play on a DVD player Help Plz
By Ruudboy in forum Newbie / General discussionsReplies: 9Last Post: 13th Dec 2008, 02:09 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 13:39 -
Help on Dual Layer DVD
By mn072065 in forum DVD RippingReplies: 9Last Post: 16th May 2007, 09:36 -
DVD dual layer help
By Dan206 in forum Newbie / General discussionsReplies: 5Last Post: 8th May 2007, 09:22
