What is a .ratDVD file? What can I do with it? How do I burn it? How do I cnovert it so I can make a VCD?
RATdvd
ratDVD takes a full featured DVD movie and puts it into a highly compressed video format file - while preserving all the features of the original DVD. You can directly play back the compressed file - with all the options the original DVD. You can also simply convert it back to the original DVD format without losing any features(but you will lose video quality).You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Last night I tried to play the .raDVD file in the latest version of Windows Media Player, like it is claimed can be done, and it crashed. There was a error message loading codec.
So much for that. -
You could just buy the original or wait for it to come out officially.
Google "What is a .ratDVD file":
http://www.google.com.au/search?hl=en&q=what+is+a+.ratDVD+file&meta=
It's a compressed file that can retain all features of a DVD such as menus, etc in one self-contained file that is able to be played by Windows Media Player.Originally Posted by corumz
Whatever you want. Most people would either watch it, convert it and/or burn itOriginally Posted by corumz
You can burn it as data which gives you a .ratDVD file on a data disc, or if you mean as something playable in a settop DVD player, then you need to use ratDVD to convert it back to the original DVD folders, and then burn that as per normal.Originally Posted by corumz
See above to convert it back to a VIDEO_TS folder. Then use the usual tools. Most likely there's still guides in the guide ssection for this also.Originally Posted by corumzIf in doubt, Google it.
Video file extensions cheat?
By stealedcircle in forum Newbie / General discussionsReplies: 9Last Post: 4th Feb 2012, 12:42 -
File types and DVD player
By rogmath in forum Newbie / General discussionsReplies: 10Last Post: 7th Jan 2011, 15:24 -
Putting different types of file formats on to DVD-R
By carl606 in forum Newbie / General discussionsReplies: 10Last Post: 11th Mar 2010, 06:11 -
Which DVD Player For Under $50 Plays Most Downloaded File Types
By DJboutit in forum DVD & Blu-ray PlayersReplies: 10Last Post: 6th Jan 2010, 15:55 -
How to change file extensions
By tweedledee in forum ComputerReplies: 23Last Post: 8th Jun 2007, 15:43
