all my work so far has been with analog capture. I borrowed a JVC digital camera and now want to get the video into a file. I have looked at two programs, one is MS Movie Maker from XP and the other is Ulead Video Studio. Both make me choose the resolution and frames per second! This does not make sense to me. Seems like I want to simply transfer it at the resolution/fps it was recorded at... Why doesn't it just transfer the data in without me specifying anything? In fact, I am not even sure of the resolution of the camera. Specs say DV format (SD mode) and signal format of NTSC. I thought it would be mpeg2... Can someone explain this...
Can someone tell me what resolution and format the DV is originally recorded in?
If you're in NTSC, use 720x480, 29.97fps. You should be able to see this in the Video Comparisons link...
http://www.vcdhelp.com/comparison.htm
If you're using a firewire card, your setup should yield a huge file in DV AVI format, with a rate of 3.6MB/sec.
What you're seeing is kinda weird, as DV format is 'FIXED'...unless you're 'NOT' using firewire port to transfer.
hope this helps. -
Sounds like I may not have set up my capture correctly for DV and it still thinks it is capturing from my ATI AIW128 card... Thanks for the help, will look some more at setup.
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 11:26 -
Confused ~~ Capture FIOS HDTV??
By Ghost2099 in forum Capturing and VCRReplies: 7Last Post: 17th Sep 2010, 09:26 -
Capture...convert...confused!!!
By cyber-junkie in forum Newbie / General discussionsReplies: 10Last Post: 15th Jan 2010, 13:11 -
Confused about my video capture card needs
By Yogensha in forum Capturing and VCRReplies: 19Last Post: 4th Nov 2008, 04:41 -
new...confused..how to capture from dvd to dv
By ldubb619 in forum Newbie / General discussionsReplies: 2Last Post: 29th Jun 2007, 15:22
