I burned several home made clips on dvd . I wanted to use filter to adjust the lighting and I used TMPGEnc 3.0 Express to extract the files from my dvd and adjusted lighting and as Output I used DVD NTSC to save .
I used Sonic My Dvd to burn it , but I got a message telling me the Data Rate is too high for DVD.
Is Data Rate same as Bit rate and if TMPGE saved it as DVD, should it not burn . Or did I have to use a different format for Output , like AVI
Other programs I have tried to use to burn, did not recognize the file format used by TMPGE, only Sonic My Dvd did .
I'm assuming the 'data rate' is probably a combination of the video and audio bitrates. Max bitrate for a DVD is about 9800 kbps 'data rate'.
Many players can still work above that datarate, but to be on the safe side, I generally use around 8000kbps max. I don't use TMPGEnc Express, but that sounds like the right format you are using.
After formatting to MPEG-2, you have to author the file before you burn. I'm assuming that's what 'My DVD' is doing. If the MPEG-2 files are DVD compliant, any authoring program should be able to use them.
If you look to the left <<<< under 'What is' DVD, you can see all the DVD specifications. -
Thanks for the reply.
I used TMPPGEnc Dvd Author 1.6 and it created the dvd with no problem .
That Sonic MyDvd must be an outdated software that could not handle higher bitrate .
firmware burning problem
By weedhopper in forum DVD & Blu-ray PlayersReplies: 6Last Post: 1st Aug 2010, 12:34 -
BDMV burning problem
By rickoshay in forum Authoring (Blu-ray)Replies: 2Last Post: 12th Jun 2010, 05:48 -
Problem with burning.
By googoodolls in forum DVD & Blu-ray WritersReplies: 7Last Post: 12th Dec 2009, 07:20 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Burning tracking problem or software problem???
By yogart in forum Authoring (DVD)Replies: 2Last Post: 24th May 2007, 13:39
