Results 1 to 13 of 13
  1. Member SE14man's Avatar
    Jul 2005
    Queensland
    At work my friend Omar gave me his hard drive to fix.
    He is running Windows 2000.
    At start up it says something and has that bue screen of death un fortinaty i cant remember the error but it said try chkdsk /f and check for viruses.
    I used it as a slave to check for bad sectors and it found none.
    Now at start up it wont even come up with that blue screen it just says verifying dmi pool data and thats it, it just stops there.
    (This is the drive set to the master)
    So what do i do?
    Im not guna go install windows 2000 on it again because he doesnt deserve it.
    What can i do to try and fix it tho.
    I cant even get into safe mode.
    Surely id need to set it as a slave and do something to it in windows to make it boot properly as a master.
    I even configured it as a master in the bios by making it the only HDD connected but still no luck!!
    Ne1??
  2. The drive is:
    A.Infected with a virus and the DMI pool/autoexec is corrupt.
    B.Windows files are corrupt.
    C.Locked up due to a hardware problem.
    Solution:
    Use a virus utility,do a clean install or buy a new one.
    BTW...what's with the religous reference?
  3. Originally Posted by SE14man
    Is this a Brand?
  4. Member SE14man's Avatar
    Jul 2005
    Queensland
    No i was just joking around.
    Does Windows 2000 have a boot.ini, if not what does it use to boot?
    Your sense of humor sucks. Don't do that again. Consider this an informal warning. Your post has been edited to remove the "jokes".
  6. Member GKar's Avatar
    Jul 2003
    In the corner, on a stool
    You can try FDISK/MBR to replace the master boot record incase it is corrupt.
  7. Member SE14man's Avatar
    Jul 2005
    Queensland
    OK mate cheers,
    Just tryna find a Windows 2000 boot disk and see if that wld work form a foppy? Do they exist?
  8. Mod Neophyte redwudz's Avatar
    USA
    For bootdisks, try here: http://www.bootdisk.com/bootdisk.htm
  9. Member SE14man's Avatar
    Jul 2005
    Queensland
    Cheers for that mate,
    What about a Win2K Emergency Repair Disk?
  10. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    LS
    canadateck wrote
    SE14man wrote:
    (This is the (word edited by gll99) drive set to the master)
    Might be good if you or canadateck edited the quoted text also.
  11. Member SE14man's Avatar
    Jul 2005
    Queensland
    OK, I'm sorry, I won't let it happen again.
  12. Member SE14man's Avatar
    Jul 2005
    Queensland
    Thanks Redwudz no offence but that was as much use as a chocolate fireguard because i cant get into Win2k can i because the boot is donald ducked.
    Hehe at least ya tried tho mate thnaks 4 the other links
