Hi there, I've finally got myself a DVD writer so no more VCD ! ! ! Woohooo!!!! I know this has been asked a million times but i was wondering what the best method to convert AVI to DVD. I am inclined to use TMPGEnc 2.5 (also have TMPGEnc xpresss 3.0 never used though) as this gave high quality VCD's. Or is there a more simplistic program. I've heard DVD Santa and CCE mentioned alot. Does they still give best available quality. Any recommendations? Quality is more inportant than speed and i wont be using subs.
Regards Jim
Results 1 to 20 of 20
Source?
Maybe you can have a try on winavi which can convert AVI to DVD with very stunning video and audio quality! Actually, I used this program for a long time and find it is pretty good though it is not free!
One-click wonder:
divxtodvd
The manual way:
http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm
Further info in the guides section to the left.If in doubt, Google it. -
the car dvd player that I am thinking of getting only plays region 1 dvds. If I do a conversion of mpg to dvd format, how does the player know what region it is? Will it play?
Is there a way to convert vcd to dvd format? -
does dvixtoDVD do both vcd to dvd as well as mpg to dvd (all no region outcomes)
How do you convert a bunch of files at a time? And how do I know how many mpg files I can convert to fit on a 4.7 gig dvd-r? IS it essentially the same size after conversion?
Approximately how long does it take?
thanks! -
I downloaded TMPGEnc DVD Authoring. Is there a difference between that and TMPGEnc?
When I try to add the file, some mpg will be ok while others will say "a sequence header is necessary for every GOP in DVD" I dont know what that means, these two files are the same but one works?
Also, it says below that I have used 59 mb (which is the size of the mpg) which is misleading becuase when I used divxtoDVD, my 59 mb came out to 125 mb. How do I keep track on a 4.7 gig dvd-r?
Jason -
Originally Posted by jyeh74"Art is making something out of nothing and selling it." - Frank Zappa
TMPGEnc 3.0 XPress is the best one? I think version 2.5 is confusing
Also, stupid question, bitrate is 9 or 10? Whats interlace versus non-interlace? -
hello everyone. i have been using DVDs Unlimited to burn my avi files onto a dvd. although i have realised that ones i play the dvd on my dvd player connected to the tv the movie pauses a few times and sometimes the sound doesnt match the picture.
i have a 2x dvd burner, i dont know if that is the problem or i am not using a good program...
please help"Hell is empty. All the devils are here." -
n3mi:-IMO, probably crap/cheap media. Change/get better quality media and see the difference.
so u think i should get better dvdz.. that could be right i do have very cheap ones hehe
wat would be the best program for converting avi files onto dvd's??
Originally Posted by n3mi
https://www.videohelp.com/forum/viewtopic.php?p=1387321#1387321If in doubt, Google it.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
