Poll: Favorite video compression codec for small file size needs?
Be advised that this is a public poll: other users can see the choice(s) you selected.
Results 1 to 16 of 16
  1. I'm a MEGA Super Moderator Baldrick's Avatar
    I use wmv9.
    Thanks to yoda313 for the poll idea ( https://www.videohelp.com/forum/viewtopic.php?t=281421 )
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Thank you baldrick (Divx for me )
    Jun 2004
    USA
    wmv9
    bits
  4. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Xvid
  5. Member rhegedus's Avatar
    on the jazz
    wmv
    Regards,
    Rob
  6. Member dipstick's Avatar
    Jan 2005
    Dark side of the Moon
    wmv9.
    Quality and compatability.
    I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix,
  7. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    It depends on your what you want to do with your small file. If it means giving it to somebody unknown, then wmv is the most compatible.
    http://www.kiva.org/about
  8. WMV, I'm amazed at the quality you get at such a small file size.
  9. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    Almost everything I do is destined for DVD so the only option is MPEG2/MPEG1.
    Buy My Books
  10. Member dragon_1's Avatar
    Jul 2005
    i don't know
    Xvid all the way
  11. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    WMV
    If in doubt, Google it.
  12. MPG1 or MPG2 because they don't need a lot of CPU power to be played.
  13. i like to use tmpgenc and convert to mpeg 1 using the kvcd template
    ----> adamf9898 ---->
  14. Member lumis's Avatar
    Jan 2005
    the remnants of pangea
    xvid.
  15. Member doppletwo's Avatar
    Dec 2004
    United States, Earff
    Matters what you mena by small.
    For tiny I use WMV. By tiny I mean, if it need to be less than 100MB.
    Anything larger and I go with MPEG2.
    snappy phrase
    I don't know what you're talking about.
  16. Member Heywould3's Avatar
    Apr 2002
    always on the move
    im either xvid or divx.. i havnet tried wmv9 but i like the quality vs file size.. and i have a divx/xvid dvd player it might play wmv too.. but ive never seen real good guality from that format. prolly cuz i stoped looking
