This is the first disc of a two-disc set. The second disc copies perfectly.
The first disc, cracked on decrypter and shrunk on shrink 3.2 using default settings won't allow subtitles to be turned off.
I can't re-author, either, removing the subtitles entirely, as their is non-English speech occurant in the movie and therefore they need to be there, but only activated at certain times.
Any suggestions?
As no-one has bothered replying, I thought I'd hazzard a guess to get things moving.
I have the file as an uncompressed VIDEO_TS folder decrypted from the original using DVDFabDecrypter and using Power DVD the movie can be played on the computer without subtitles.
When I shrink the file, the compression makes it so that the subtitles are defaulting as on, and although you can turn them off, the next speech will trigger them back in. Re-authoring is out as the subtitles are necessary in parts when non-English is spoken.
Is my only solution, then, to burn to DL?
Anyone???
Ripping Region 1 disc to burn Region 2/Free ?
By Alan Rouge in forum DVD RippingReplies: 7Last Post: 28th Sep 2010, 21:09 -
How to strip audio or subtitle tracks off a Blu-Ray Disc
By ppeterr in forum Authoring (Blu-ray)Replies: 6Last Post: 2nd Jul 2010, 13:45 -
How to keep subtitle text from looking ragged in final disc image???!!
By wildgeese in forum ffmpegX general discussionReplies: 8Last Post: 24th Feb 2009, 14:40 -
Problem expanding subtitle time with Subtitle Workshop
By Kaze105 in forum SubtitleReplies: 1Last Post: 11th Nov 2008, 22:16 -
Region1 disc... need to backup to region 0
By snadge in forum DVD RippingReplies: 11Last Post: 1st Mar 2008, 13:25
