Ok, I have an Xbox that I use as a media center and my Comcast digital cable box hooked up to my HDTV. Both are connected through component (obviously).
Since I live in a fairly small apartment, I'd like to get some kind of 5.1 sound option going that is under $300. Does anyone have some recommendations or ideas they can share? Would the Logitech Z5500 speakers be good enough for something like this or is it better to get a "true" home theater system?
Thanks![]()
If I had a budget of $300 I'd get a dedicated system. But being in an apartment there is no need to go overboard.
Something like this should do fine.
http://www.newegg.com/Product/Product.asp?Item=N82E16882115047
Edit: better price here: http://www.electronics-expo.com/product.jsp?x=YHT160&zipz=11001 -
I agree with Flaystus...
I tried to use a set of Logitech 5.1 to go with a DVD hooked up to a 13" tv in my office. The speakers worked well for the computer (close proximity) but just didn't cut it with filling the room with sound for the DVD (even with a small office - 9x14) -
Thanks for the replies
I actually was looking at the Yamaha YHT 360 but it was a bit more than I wanted to spend. The 160 seems more in tune with my needs. And it's from newegg, I had no idea they carried that.
Thanks again!
1920x800 MKV -> Bluray disc. Any good option?
By Asterra in forum Newbie / General discussionsReplies: 2Last Post: 18th Dec 2011, 20:48 -
Cheap DVD-R Any Good?
By adalect in forum MediaReplies: 32Last Post: 28th Mar 2010, 21:45 -
Looking for a cheap and good standalone DVD player
By Kweldood in forum DVD & Blu-ray PlayersReplies: 9Last Post: 28th May 2009, 07:54 -
Good CHEAP HD Capture software
By Johnny Boy in forum Newbie / General discussionsReplies: 2Last Post: 18th Mar 2009, 21:41 -
Replacing my Osprey2000 - need something cheap but good
By tonyp2 in forum Capturing and VCRReplies: 16Last Post: 25th Feb 2009, 16:51
