With my collection of dvds i have , and i have some on my drive too.I would like to know what program is easy to use in order to put more than one movie onto a blank dvd disk with menus.I want to be able to have more than one movie on a blank dvd and when i put the disk into my player i can choose from what movie i want to watch.Also the same going for movies that have more than one part to them for example part 1 and 2 of the same movie on one disk with a menu to pick what part you would like to watch.Can you suggest a easy and very simple program that would do that for me to use please.![]()
Are we talking about preserving all the menus or a simple menu to select each movie?
"Art is making something out of nothing and selling it." - Frank Zappa -
Sure but you are going to get lousy results. Quality wize your movies are going to suffer. If that does not bother you then use DVD Shrink and reauthor. No menus though.
You can rip to MPG 2 with TDA as long as you have AnyDVD running if you need to defeat protections. If not you can simply rip to the first movie as track 1 and the second one as track 2 then make a menu for them. You will not be able to keep the original menus. Thats the easiest way to achieve that. There are other more difficult methods that may allow you to keep the original methods but I'am not experienced enough to suggest how.No DVD can withstand the power of DVDShrink along with AnyDVD!
Creating menus: DVD Styler re-encoding question.......
By bahjan in forum Authoring (DVD)Replies: 3Last Post: 21st Dec 2011, 05:54 -
Nero 8 DVD menus simulate fine but transcode errors on final dvd movie
By perfection in forum Authoring (DVD)Replies: 1Last Post: 1st Nov 2008, 03:01 -
Always on Menus HD DVD Question
By xpanq in forum MacReplies: 1Last Post: 24th Jan 2008, 05:43 -
Magix Movie Edit Pro Menus and Sub-menus
By gayclarke in forum Authoring (DVD)Replies: 8Last Post: 11th Aug 2007, 10:07 -
Vegas Movie Studio+DVD Platinum Edition Menus
By ccarver in forum EditingReplies: 1Last Post: 7th Jun 2007, 18:53
