Hello!
I have TMPGenc Plus 2.524 installed. I also have PowerDVD 6 installed. Apparently you are supposed to get the Cyberlink Mpeg 2 decoder installed then. And GSpot lists that codec as one of my installed codecs so I guess I have it then!.
I would like to do some experiments with TMPGEnc and that decoder to see if it converts Xvids to SVCD faster and with higher quality then the built in one in TMPGEnc the CRI sofdec one. But for some reason the Cyberlink MPEG 2 decoder wont show up under the VFAPI plug Ins in TMPGEnc. Why is that what could be wrong??![]()
I was looking forward to experiment but I can not start if it wont show up there!.
Sincerely Joakim Agren!
Originally Posted by jimmalenko
Besides I love the challenge to try to create as good SVCD quality wise as possible!.Sincerely Joakim Agren! -
I think you missed to point I was trying to make.
The decoding side of things handles the decompression of a compressed file back to raw uncompressed video so that the encoder can then encode it to another compressed file. Therefore if your source is XviD, you only need an XviD codec to handle the decompression part. TMPGEnc will use it's own internal MPEG-2 routines to handle the encoding side of things. AFAIK it cannot use 3rd party codecs when encoding MPEG. Therefore you do not need the PowerDVD codec at all for the whole decoding/encoding part of this operation.
Certainly if your source was MPEG-2, then you would have a valid point as you could specify which MPEG codec you want to be doing the decompression.If in doubt, Google it. -
So the VFAPI plug ins only controls the Input source file and if TMPGenc is able to read it as a source for encoding!. I never knew that!
So I guess this is not my concern at the moment. But it bugs me that it wont show up there as a plug in because it should be there!. Do you know what could be the fault??
Also do you think that TMPGEnc is the best encoder for MPEG??
Or do you recommend something else??
I am in the mood to experiment a little!!8)
Originally Posted by Joakim_A
I think it's not a fault. It can be that TMPGEnc doesn't use the PowerDVD decoder and thus it's not showing in his list. I can imagine there are more A/V codecs installed on your pc that don't show up in that list?
When you want to experiment with mpeg2 encoders, try Canopus Procoder 1.5 or CCE. I've had some good experiences with them, but they take a fair chunk of time tho . . .
good luck
cheers -
TMPGENC can use Cyberlink to decode MPEG if it's installed. It's certainly a decent one too.
Cyberlink PowerDirector 7 can't capture using MPEG2 Widescreen...
By El Xando in forum Capturing and VCRReplies: 3Last Post: 4th Aug 2009, 23:58 -
Cyberlink Power Director 7 - "Create" Function Problems!
By lapetite_66 in forum Newbie / General discussionsReplies: 4Last Post: 29th Jul 2009, 20:01 -
I have a question about cyberlink powerdirector 6.
By ingeborgdot in forum Authoring (DVD)Replies: 4Last Post: 3rd Nov 2007, 21:31 -
TMPGEnc problems with RMVB -> Mpeg2 conversion
By rebel316 in forum Video ConversionReplies: 2Last Post: 7th Aug 2007, 04:33 -
Cyberlink Director
By micromack in forum Authoring (DVD)Replies: 1Last Post: 1st Jun 2007, 16:38
