  1. I was burning SVCD with Nero 5554. Over 750MB mpeg-2 barely squeezed in. Lead-in and tracks finished smoothly. But Nero took longer than usual writing lead-out, then display this error message:
    invalid write state
    couldn't finish Disc-At-Once
    This really pissed me off, buring process failed at 99.99 percent. What's wrong here?
    Thanks for your help.
  2. Poplar,
    Give more detail as to what disc size have you used. I got a feeling you're using 650 MB/74 min disc. It could fit the disc however, you'll need to turn on the over-burn option. Or you could simply use a 700 MB/80 min. This might be one possibility. Not quite sure. Jordan
