I've searched the Help section and these forums, but I can't seem to find the answer. How do I tell DVD Lab Pro which Movie/Clip should be 'First Play' (ie. before the Menu) ? Thanks.
Look at the connections window in DLP. You will see a green circle marked (surprise !) 'First Play'. Draw a connection from this to the item you want to play first, than from that item to the first menu. If you actually read the manual/help file that comes with DLP you will find it has a section marked 'First Play' that has pictures and everything.
Read my blog here.
dvd lab pro movie numbers regularise
By sumeshkri in forum Newbie / General discussionsReplies: 1Last Post: 24th Oct 2010, 02:28 -
DVD-Lab Pro 2: How to set a looped video as background of a menu?
By Stern77 in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2010, 12:00 -
DVD Lab Pro Play all
By milway in forum Authoring (DVD)Replies: 5Last Post: 10th May 2008, 05:10 -
DVD Lab Pro - Question about movie merge
By shashidar in forum Authoring (DVD)Replies: 4Last Post: 17th Jan 2008, 16:41 -
DVD Lab Pro - Movie clips in menu
By flipzoso in forum Authoring (DVD)Replies: 1Last Post: 26th Oct 2007, 03:38
