    Mar 2005
    Southeast
    I am using TMPGEnc DVD Author which I think is a hell of a lot better than DVD Remake Pro (which I drop $50 on, damn!). I have merged my dvds together got my chapter menu all set up but I want to know how can I add audio to the chapter menu screen? Can this be done in TMPGEnc DVD Author or do I need to use another tool, if so what tool?
    Thanx
    Apr 2004
    Miskatonic U
    I believe you can only do it by creating a video clip with a still farme and your audio (effectively a motion menu, sans motion).
    Read my blog here.
    Mar 2005
    Southeast
    I dont want stills I want motion menus with some sort of audio. I dont need the audio to be per clip I just want it to be for the menu itself.
    How can I do this? I refuse to continue to spend cash on tools that do not complete the job. DVD Remake Pro does a good merge, TMPGenc does a better one in my eyes, but I hear that DVDLab Pro does even a better job.
    I just want a tool that will allow me to merge my dvds, create my own still or motion menus and add some sort of audio background to the menu screen so that it is not silent death when the menu is displayed.
    Help me out. Thanx
    Apr 2004
    Miskatonic U
    I guess I didn't use small enough words. In tmpgenc DVD author, only motion menus can have audio. The simplest motion menu would be a video clip with a still picture and appropriate audio. If this is too hard for you to work out how to do, stay away from DVD Lab Pro, which is 100 times harder to use than TDA.
    Read my blog here.
    Mar 2005
    Southeast
    Thank you for the feedback, and please keep in mind that ignorance is everywhere. Its in homes, schools, on the net and in the whitehouse.
    Keep thinking small!
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Exactly. That's no excuse to keep the status quo, though
    DVDRemake Pro would be the best tool if you wanted to keep all original menus of both DVDs.
    If you're happy to create your own, then TMPGEnc DVD Author can do a nice job as you've already found out.
    To echo what guns1inger said, if you want audio on menus in TDA, then you need to use an encoder to create a DVD-compliant MPEG, which can comprise either video of some description with audio, or a still frame with audio.
    I'm certain this has been described in greater detail here before. Maybe a forum search on "tda motion menu" might provide some helpful responses ?
    If in doubt, Google it.
    Mar 2003
    Kansas City MO
    Add your clip (Audio with Video) into the Menu, its that simple.
