Almost file xvid after converted, i got this message at the begin of the movie :
WARNING : NOTHING TO OUTPUT BFRAME DECODER LAG
I dont know why? anyone have the same problem with me ? How you fix it
Thanks !!
Sounds like MP3 VBR audio. That's usually the error from VirtualDub when you have it. Save out the audio as a WAV file with VirtualDub, then use that audio, along with the original video to encode.
First of all it isn't an error. It has nothing to do with VBR mp3 or audio at all.
It is simply because you have a file encoded with bframes that aren't packed and you are decoding via VfW. There lag frame is there because VfW wasn't designed for and can't handle bframes. This is because VfW works as basically one frame in, one frame out.
Pretty sure though that for some time now XviD has just outputted a black frame instead of that message. What version/build are you running?
Basically to fix it. Don't decode via VfW.
Enconding Megui Xvid error :/
By psygno in forum DVD RippingReplies: 0Last Post: 2nd Sep 2011, 06:27 -
Color streaks appears once converted to Xvid
By 24fps in forum Video ConversionReplies: 5Last Post: 17th Jan 2011, 03:45 -
Error Converting to Xvid
By Davop in forum DVD RippingReplies: 2Last Post: 23rd Jan 2010, 05:06 -
xVid in Premiere CS3 Error
By goodjj22 in forum Video ConversionReplies: 2Last Post: 20th Mar 2008, 14:49 -
NEWBIE - Converted and burned XVID to DVD -- Blurry/boxy on TV
By baldieme in forum Newbie / General discussionsReplies: 4Last Post: 7th Feb 2008, 17:47
