If you could add any one feature or change one thing about your current or favorate Operating System what would it be?
Its a subject I've given a lot of thought in the past. I've actually conceptualized pretty much an entire OS in my head in the past. Heck I think I posted a bit about it here long ago.
So what would you change?
Personally I wouldn't allow an offical codec on the system unless it was installed into a specific directory via auto installer or drag and drop. That way codec problems would be as easy to troubleshoot as moving files out of the directory.
Also it would keep crap like real player from forcing your player choice. Of course in this day of DRM thats beem complicated quite a bit.
Results 1 to 23 of 23
I would want options of what should and shouldn't be installed with windows. For example, given the choice not to install windows messenger, outlook express, WMP, etc.. I know you can remove them afterwards but i would like the option of not installing them during windows setup.
Originally Posted by waheed
I'd like a TRUE DOS mode for gaming.
I'd like to be able to pick and choose any former os WITHOUT owning seperate modules. That way EMULATION would be a thing of the past. With harddrives the way they are I'd like to have it all built in WITHOUT PARTITIONING. How hard could it be to tell your system to function EXACLTY like a previous os??? I mean the amounts of ram and disc space we have now should make true os backward compatiblity absolutely perfect.
Thats the one edge that console gaming has over the pc. Sure you can't upgrade the power of consoles like you can on a pc. BUT 6 years from now you can dig out the console, pop in a game and play (assuming you haven't beaten it up over the years).
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
No. registry. whatsoever.
Give me the old days when you could simply "uninstall" a program by deleting it directory (folder, for those not born in the 1800's like me). Just have a simple ini (which you can tweak) in the program directory. -
Originally Posted by Supreme2k
Originally Posted by jimmalenkoDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Well, the concept is the same.
If you're talking about putting the console and the game in the cupboard then retrieving it later, there's no reason why you couldn't have done the same with your old PC and game and bought a new PC. Especially in this day and age where if your computer is getting on quite a bit, it is probably advantageous from both a price and performance point of view to buy new as opposed to upgrading mobo, CPU, RAM & hard drive, at the very least.
FWIW I'm rebuilding a machine specifically just for playing my older games. I've still got an old tower from 1998 or so that will do fine running Win98.If in doubt, Google it. -
The separate reg files would be a nice feature. I would also like to see error messages that told you what the error actually was.
Originally Posted by hudsonfDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
My biggest problem with the OS (and many "modern" programs) is bloat.
Why is it that I have many programs (usually DOS) that are still in the K range of space, that can do the same thing as some of this flashy gig software?
There is actual freeware coming out now that does the same thing as some of this $$$$ payware, with under a meg footprint (pdf creation, ftp servers, image editing, to name a few).
Wasn't there a site where they had some pretty amazing stuff done in under 100k? It may have been lower, which is why I'm having a hared time finding it.
EDIT: Not the exact one, but something similar:
http://www.maa.org/editorial/mathgames/mathgames_08_16_04.html -
Originally Posted by Mister Flonk-Flonk
Just $100? Have you seen what MS actual XP Pro full version retail price is at the stores? Its insane!
No blue screen of death, errors, random crashes...you get the picture.
Originally Posted by waheedDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Originally Posted by yoda313
1) User don't know what the ****. They assume macs are crash proof and load every bit of crappy ass software onto the system. Norton System Works also sometimes causes issue. Norton should be destroyed. Or they never update or they update constantly but never do any basic mantainace on the system.
or...
2) They have a hardware problem.
Macs DO crash, just alot less then most PCs. Of course this is a gap that has been closed greatly by Windows 2k and XP. -
I don't think I've ever even used a Mac
. Closest I've come to one is using a Mac theme
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 18:07 -
looking for some clarification on current projectors
By Seeker47 in forum DVB / IPTVReplies: 7Last Post: 2nd Nov 2009, 10:48 -
What's up with ffmpegx (current and 1.0.0)
By TryNiX in forum ffmpegX general discussionReplies: 5Last Post: 15th Apr 2009, 13:46 -
Current Situation re. +R and -R
By nlec in forum MediaReplies: 1Last Post: 23rd Sep 2008, 15:59 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58
