  1. I'm trying to rip a DVD so that it will play on my TiVo. I've looked at all the tutorials out there but nothing seems to work. Does anyone have any suggestions?
  2. Member rkr1958's Avatar
    Feb 2002
    Huntsville, AL, USA
    I'm not sure I understand what you're trying to do? Are you trying to copy a ripped DVD to you TIVO harddrive in order to play it with your TIVO player? If that's the case I assue your TIVO unit doesn't have a DVDRW drive and you'd be copying your file via network connection. If so, I don't have a clue if and how you could do that. Usually people want to go the other way (TIVO to DVD).
    Mar 2003
    Kansas City MO
    Really, never have I heard anyone wanting to do this which is not going to happen. Don't you own a DVD Player?
    Aug 2005
    California, USA
    If you create a mpeg2 file and place it in your TIVO file on your hard drive and have set up your computer as a server you can transfer the file to your TIVO and play it on TV. The size of the file thats needed I don't know.
  5. With the newest tivo desktop software you can set a folder on your computer to share with any tivo on the network. there are certain file restrictions (mpeg files with certain resolutions and bitrates). I am able to transfer other recordings but can't transfer my dvd's. the reason i want to do this is because i keep all of my dvd's on my computer (i have a lot of storage space).
