I keep getting the error that there isn't enough room in my prepare folder. I cleared up up to 4GB's thinking that perhaps the preparation requires a size equal o the project and... well I was wrong. Any thoughts on what it could be? I tried searching around but I couldn't find anything in the guides. Thanks in advance.
You said you cleared up to 4 GBs but SL DVD - or + R discs (I guess you're burning a SL disc, aren't you?!) need a little more room than that. And of course there must be enough room for your OS.
Dumb question, I know. Did you cleaned out your Recycle Bin as well?
Matters of great concern should be taken lightly.
Matters of small concern should be taken seriously. -
Ah so that's the case. Yeah I cleaned out pretty much everything. Guess I'll have to trim some more music. Thanks.
DVD Architect Languages problem
By Compo in forum DVD RippingReplies: 2Last Post: 23rd Jun 2011, 07:47 -
DVD Architect 3.0 problem
By Jvance in forum Authoring (DVD)Replies: 3Last Post: 1st Jan 2009, 18:58 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
AC3 problem in DVD Architect
By blackberryf1 in forum Authoring (DVD)Replies: 0Last Post: 1st Mar 2008, 10:25 -
DVD Architect Audio problem
By Just Mike in forum Authoring (DVD)Replies: 3Last Post: 12th Aug 2007, 02:11
