I'm even more unsure after research and reading the many previous posts on this topic.
I wonder if there is a true "upgrade" for an old WinTV-FM (878 chip) capture card. I want to continue capturing uncompressed AVI and require no tuner capabilities. There must be at minimum composite and s-video inputs. No video out is required. Preference is to use VirtualDub and Huffyuv to cap. USA/NTSC
I have a MyHD card for capturing ATSC which also has the capability of analog but unfortunately does an internal conversion/deinterlace rendering it inferior even to the WinTV.
Any info on a hot new chip or clean card would be greatly appreciated.
Thanks,
golem
Yes there is. Later Conexant solutions (10 and 12 bit ones) do have a far better picture.
Also Philips chipset based capture cards, have an excellent picture (even if they are only 9-bit)
bt8xx cards still do their job excellent through.La Linea by Osvaldo Cavandoli
Thanks guys for the replies!
@SatStorm
Thanks for the heads-up regarding the Conexant CX238** series. Further research seems to show the Leadtek Winfast Expert to be the card of choice in the 10 bit world. Stll unable to locate any non-hardware encoding cards with a 12 bit chip.
@The_Doman
Yup, you are so right! Have been using the BTWINCAP drivers since forever. It truly is a must for anyone able to use 'em.
Additional opinions on card candidates cheerfully accepted.
video capture card advice
By MikeClark in forum Capturing and VCRReplies: 3Last Post: 10th Nov 2011, 22:10 -
Capture Card Upgrade
By wcwman28 in forum Capturing and VCRReplies: 13Last Post: 27th Oct 2008, 20:22 -
Hauppague WinTV-HVR-1600 vs Avermedia capture card with SAA7130 chip
By johnnyquid in forum Capturing and VCRReplies: 1Last Post: 23rd Mar 2008, 18:29 -
Hauppauge WinTV 2Go capture card was Kworld DVD Maker USB 2.0
By Vampire74 in forum Capturing and VCRReplies: 4Last Post: 19th Jan 2008, 09:59 -
Unable to capture from camcorder with WinTV-PVR 250 card and and WinTV2000
By forestial in forum Capturing and VCRReplies: 1Last Post: 29th Dec 2007, 19:00
