I have two avi files and two .srt files.
It would be fine if I wanted to make two discs, because the numbering and timing on each of the srt files starts from 0.
Combining the avi files is easy.
What I want to do is combine both srt files so that the second runs in correct timing after the first. I have loaded them both into Subtitle Workshop but they seem to save only as one or the other.
What's the answer?
Thanks.
use the join feature in subtitle workshop, i think it is under Tools.
...and read the help file in Subtitle Workshop.Originally Posted by Baldrick
Fortunately I had posted on another site and got an answer that mentioned things I had not done, but thanks anyway. For a more thorough answer:
http://divxstation.com/article.asp?aId=103 -
It's simple...use subtitle workshop. Open join video file in subtitle workshop. Next open the second part (CD 2) subtitle .srt file. Drag the video slider to the timeframe where the first subtitle should be, click on first subtitle. Click mark as first sync point, drag the slider to the end of the last subtitle on video, click on last subtile. click mark as last sync point. From there..click yes to re sync subtitle. Now click on tools, join subtitle, add the two subtitle files cd1 srt cd 2 srt. , uncheck recalculate time. There you go...you have combine the two subtitle file into one with re sync time .
Hello,
SRTmerger.org is dead... RIP
After 2 weeks of research, i contact Timur, the owner of
http://easypronunciation.com/en/merge-two-subtitle-files-online
Timur took hours to make a tool better than srtmerger.org.
I suggest everyone to use and share this like:
This is the only good solution to merge 2 srt subtitles!
Thanks to Timur for your time and for your amazing work!
Please share...
Gribs
Combine/merge two subrip srt of different languages into one
By leesing2k in forum SubtitleReplies: 8Last Post: 18th Apr 2016, 15:08 -
How would I combine 2 avi files into one?
By Variable in forum Newbie / General discussionsReplies: 7Last Post: 27th Sep 2010, 17:50 -
Combine .mkv and .srt files (hardcode)
By tripster23 in forum SubtitleReplies: 7Last Post: 26th Mar 2009, 15:04 -
trying to combine quicktime files
By dwayne00 in forum Newbie / General discussionsReplies: 3Last Post: 4th Apr 2008, 20:09 -
How do you combine .vob files?
By xoADAMox in forum Newbie / General discussionsReplies: 1Last Post: 19th Jun 2007, 02:04
