    May 2003
    Israel
    Hi,
    I have DVD folders (Audio and Video) on my C drive. How can I convert this to one AVI file?
    Regards,
    Uriel
  2. Member rhegedus's Avatar
    on the jazz
    See the CONVERT tab to the left of the screen..........
    Regards,
    Rob
    you can use autogk and select the .ifo file in the video_ts folder and convert to avi divx or xvid.
    or use our tools search, select dvd to avi or vob to avi under format conversion.
    May 2003
    Israel
    Hi,
    I tried to convert using SimpleDivX but got video without audio.
    Why? (Here is the GSPOT of the AVI file I got)
    Do you have other simple aplication for this?
    Uriel
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Again - AutoGK.
    Products with "Easy", "Eazy" or "Simple" in it's name is (with a few brilliant exceptions) a dead giveaway that it's crap.
    (Not that I have any experience with this "Simple" app - just a general rule)
    /Mats
  6. autogk as suggested - however I once got audio sync problems but this was due to how it was ripped (I ended up mounting the folder using daemon tools and then using dvddecrypter to rip in IFO mode - solved everything)
    autogk is dead easy to use too
