Hello.
Why i cant capture from VX1000E with firewire card,1394
have VX1000E ilink driver?
Thank you.
Results 1 to 12 of 12
There are no drivers. Ensure that your 1394 port is showing as working in Device Manage, with VX1000E switched off, connect Firewire 1394 cable, switch VX to Player and it will be detected by Windows. If it isn't, the 1394 card is faulty, the cable is faulty or the 1394 port in the VX is faulty.
Originally Posted by Richard_G
The VX1000 had a problem with the firewire 1394 port as microsoft was not compatible with it. This was especially evident in windows 2000 and supposeable fixed in xp but im not sure. I believe there is a driver or something out there so you can use the firewire but it is not a slam dunk like newer minidv cameras.
Originally Posted by Elchin
I don't know where the idea that the VX1000 had a problem came from, I've got a pair of VX700e camcorders (baby brother to the 1000e) and they have both worked first time every time under 98SE, XP SP1 and XP SP2. Plug in, switch on, transfer.
You can go for example to this forum, find some VX1000/VX1000E posts, and see that there's a lot of talk about VX1000 and XP issues:
http://www.videouniversity.com/forums/gforum.cgi?forum=8;guest=4287133638 -
ANd if the VX port is faulty,can i shoot with VX1000E then use The VX casette and capture with any camcorder(not 3CCD)?
will i get the same VX 3CCD quality? -
Thanks you!!!
It is the best message what i can read or hear the last 5 days
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 14:56 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 19:42
