The image shows my problem ....
btw ... using this tut http://web.telia.com/~u31220486/dvd2avi/dvd2avi.htm
Results 1 to 11 of 11
DON'T USE VFAPI.
What is it with all these guides recommending VFAPI. That guide has XviD devapi-4 screen shots and I am pretty sure that no one was using VFAPI since before the first devapi-4 builds.
VFAPI and VDub filters mean converting to RGB24 colourspace. This slows encoding down and reduces quality.
Use AVISynth instead. If you want something easy to use then try AutoGK which uses AVISynth, but does all the work for you. -
Re-Rip the dvd with no file splitting to one vob file.
Quality is my policy. -
13? VOB's are generally split just under 1GB. So that would be 13GB's.
Doesn't AutoGK work if you rip in ISO mode? You could always run the VOB's through DGIndex as before and then use regular GordianKnot which is more flexible than AutoGK. -
If each VOB is a different clip/chapter, then you can just use the batch mode of AutoGK and encode each to its own AVI.Originally Posted by 0verd0ze
If you want all clips merged to make one continuous AVI, you could either do the above then join the clips in virtualdub, or alternatively merge the VOBs first and then use AutoGK on the one big VOB - http://members.dodo.net.au/~jimmalenko/test.htm might assist you with the merge if you can't output to one big VOB in DVD Decrypter.If in doubt, Google it. -
NIce ... thanx alot it worked !!! ... i had problems from the beginning but it was the player so i changed it to PowerDVD and it worked !!! .
thanx alot !! my problem is now solved !!!1
love this place !
but now when i merged my 13 vobs ( around 200mb each ) , i got it splitted up in 1 gb files ... i dont wnat that
VFAPI Codec Problems
By [K]eep[A]way in forum Newbie / General discussionsReplies: 20Last Post: 8th Sep 2011, 06:40 -
VFAPI Reader Batch convert?
By Totta in forum Video ConversionReplies: 0Last Post: 20th Sep 2010, 11:44 -
VFAPI and Windows 7 64 Bit
By JekhoOne in forum Video ConversionReplies: 3Last Post: 21st Apr 2010, 13:56 -
Unexpected issue with VFAPI Reader
By NotSoEasy in forum DVD RippingReplies: 6Last Post: 8th Feb 2008, 04:29 -
VFAPI problem on Windows Vista (Home Premium)
By foochuck in forum Video ConversionReplies: 1Last Post: 3rd Nov 2007, 18:10
