In the past I converted some 352x240 AVI(DivX) to MPEG1(VCD specs), and put them in DVD to view them on TV.
My question is, would I have any benefit if instead of MPEG1 352x240 1150kbps I encode them in MPEG2 352x480?
Doubling the vertical resolution has any affect in the way they seem on a big screen TV? I only have a small TV to test and even 352x240 looks ok.
I only care on how it will look beter in a big screen TV or a projector.
thanks
Any resizing up means interpolation or "guessing" of what should go where. Some resizing algorithms do this well, others not so well. It depends a lot on your source too.
IMHO you're best to stay at 352 x 240 MPEG-1, but maybe look at bumping the bitrate up to around 1500 (if your source is good enough to warrant this kind of bitrate).
In all honesty, if we're talking big screen TVs and projectors, even commercial DVDs can look patchy / fuzzy on these devices, so I think you're expecting too much from your low-res sources.If in doubt, Google it. -
Your best bet would be to get a divx/xvid compatible DVD player. They have been going down in price, and the number of new models out that can play them has been increasing too.
The less a file is converted/encoded from one format to another, the better it looks.
Plus you can burn six 700mb .AVIs onto one DVD-R or RW and have several hours on one disc. -
Originally Posted by nebula8Quality is my policy.
Except that he's talking about keeping them as AVI for playback on an MPEG-4 capable player. And he's right.
Thanks for the clarification, (He didnt specify dvd-video or storage).
Converting AVI to DVD using DVD Flick: low quality result
By e2p in forum Video ConversionReplies: 13Last Post: 28th Oct 2010, 10:50 -
Low res in Text presentation
By jairovital in forum EditingReplies: 5Last Post: 4th Aug 2010, 17:31 -
DVD Studio Pro -select Video, Audio and Subtitle track in low res for proof
By RonCole in forum MacReplies: 3Last Post: 3rd May 2010, 12:03 -
Apple Pro Res HQ .mov convert to Huffyuv .AVI
By christianolovesvideo in forum Video ConversionReplies: 8Last Post: 6th May 2009, 13:30 -
How to reduce blocky artifacts in low res, low bitrate video
By The111 in forum Newbie / General discussionsReplies: 48Last Post: 20th Mar 2009, 18:29
