    Sep 2005
    Canada
    Hi,
    It was susscefully burning many "mpg" karaokes to a DVD by using SVCD2DVD 2. Then I put my DVD into a Regular DVD/VCD Player. It was unable to switch between Left/Right Vocal. I am wondering is it the program setting or I have to do something about it since it would be okay if I burn them as a VCD. Thanks for any help!
  2. The thing is that VCD allows you to turn individual left/right channels on or off, where as DVD doesn't. DVD only allow you to switch between different sound tracks, not left/right channels. VCD karaoke uses the fact that you can turn only the right or left channel on, so they can have vocal (and sometimes + music) on one channel and music only on the other. DVD karaoke have 2 stereo sound tracks, one with vocal and music, and one just have the music. You can then switch the audio track just like switching from English to French audio tracks. What you want to do is to create a more complex DVD with multiple sound tracks. But you'll need to find other tools in order to do that.
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    If you use v1.5 then the following may well do what you want:
    Sep 2005
    Canada
    thanks for the advise....but...why not put this function in the v2 as well?
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Because it was one of the functions which was not continued. Did it work?
