I know that this must be a simple question but I have a dvd file (created using TMPGEnc) and I am trying to burn it using Nero 6.6.0.8. Once I have selected to burn it as a dvd video file I go to select the file I want to burn. At this point I get an error message stating "file.mpg is larger that 2GB and therefore can not be stored in an ISO file system. Please use the UDF file system to write such large files". I have no idea what this means but I go and select the UDF file system and I don't believe that I will be creating a dvd video file anymore.
Can anyone help?
Results 1 to 10 of 10
Sounds like nero is expecting to burn a cd instead of a dvd. You need to make sure that you have DVD selected in nero.
Rob -
You need to author the file(s) then burn with Nero.
He's a liar and a murderer, and I say that with all due respect. -
TDA to author and burn.
...or TDA to author and create DVD structure on HDD, ImgTools Classic to create image, DVDDecrypter (or its decendant) to burn
/Mats -
Basic TDA guide: click here.
"Art is making something out of nothing and selling it." - Frank Zappa -
Thanks to everyone for your comments. What I don't understand is that I created the DVD file using TMPGEnc Express (I selected the options inside the program to create a DVD) - what I got as an end product was a large (4.6 GB) mpg file. Shouldn't I just be able to burn this in nero as a dvd video file?
mpeg video is only the video component of a DVD. As pointed out by previous posters, this does not, on it's own, a DVD make. The authoring process takes the video, audio, menus (if included) and other bits and pieces, and incorporates them into the correct structure to become a DVD. This is what you burn.
Read my blog here.
Rip DVD-R's, edit out commercials, burn new DVD Dual Layer...software?
By ruehl84 in forum Authoring (DVD)Replies: 5Last Post: 23rd Feb 2012, 04:06 -
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 17:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46
