  1. Hello, I have a large collection of .avi files. I would like to be able to burn multiple files on a dvd that will be able to play on my standalone dvd player (and hence my tv).
    I have figured out that I can make vcd's easy enough with Nero, but I would like to be able to put several .avi's onto a single dvd instead of making so many cd's.
    Also, is there a faster way to convert than using the Nero to make a single vcd? The processing takes all night!
    Thank you so much.
    C. Hersh
    Apr 2004
    Miskatonic U
    Read my blog here.
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Get a faster computer.
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    The first thing I'd check is if your player can play DivX "raw" - check out the DVD Players link to your left.
    If so, just burn as a Data DVD and you're good to go.
    If not, DivxtoDVD should make this job relatively stress-free. Either that or try the manual way:
    http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm
    There's also other 1-click tools in the Tools section here:
    https://www.videohelp.com/tools?s=35#35
    There's also other manual ways in the Guides section here:
    https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=AVI+to+DVD&h...or+List+Guides
    If in doubt, Google it.
