I was wondering if anyone out there could help!
I have been trying to join two .VOB files together. Problem is, no matter what program I use, the joined file skips, or hiccups, on playback at the point it was joined together.
This happens no matter what two .VOB files I try to join.
I have tried to use the following programs, all with no success:
1. VideoReDo
2. DVD Decrypter
3. VOBEdit and IFOEdit
4. Super Video Joiner (and about a dozen other little "joining programs")
The only thing that worked seamlessly on the video is by using the following Windows command line:
copy /b vob1.vob + vob2.vob outputfile.vob
The only problem with this method is, there's no audio in the joined file!!!
Any input on this subject will be greatly appreciated!!! I've wasted way too many hours on this one!!!
Thanks everyone!!! And happy video-ing !!!!
Regards,
Chris![]()
use tmpgenc free encoder and it's Mpeg tools function to "merge" vobs.
or...if you're goal is to author/burn the joined files to a dvd, then use tsunami dvd author to import both vobs and select to "play next file" for end of play instructions...playback will be perfectly smooth.
last option is to use tmpgenc to first convert the vobs to mpg dvd spec program streams, then do one of the two options above.
mike -
dvd lab pro will import the vobs, join them, and demux them back to elementary streams as well, if you want. free 30 day demo at the mediachance site
Read my blog here.
You can't expect to be able to join two random VOBs, as what's inside them may be totally different. One may have an AC3 stream, the other LPCM, one may have 20 subtitle streams - the other none, one may be mpeg1 video, the other mpeg2, one may be 4:3, the other 16:9 - not to mention different bitrates of the stream.
It works (at least good chances) if all VOBs are part of the same title to begin with - if not - your cances are slim.
/Mats -
Thanks guns1inger !!!
DVD Lab Pro did the trick. It joined the .VOBS seamlessly !!!!!!
Regards,
Chris
Good to know.Originally Posted by christopheramos
Thank you all.
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32 -
Joining multiple VOBs to make one AVI?
By RedCorvus in forum EditingReplies: 4Last Post: 6th Aug 2009, 10:57 -
Help Please: Joining many vobs together (Goal = My own Pop Video DVD)
By Bouldip in forum Authoring (DVD)Replies: 6Last Post: 18th Jun 2009, 18:32 -
Joining vobs without VTS and then getting VTS in the end?
By BurnBabyBurn in forum EditingReplies: 7Last Post: 23rd May 2008, 12:28 -
How to get these files to play smoothly?
By Lurkin in forum Software PlayingReplies: 3Last Post: 21st May 2007, 23:00
