Svcd2dvd sometimes goes over the dvd5 size limit, for example today I encoded a 700mb avi xvid file to dvd, the output would have been under dvd5 size, so I told it to fit to dvd 5 to get a better bitrate, it said the output file would be 4.37gb but in fact the resulting file was 4.5gb. But when I shrink a avi xvid movie to fit to dvd5 it works fine?
It depends on the source. However then next version will autoshrink if it does go over by using DVD Shrink. Drop me an email if you would like to give it a try.
Actually i will post it in the morning.
USB hard drive size limit on LG DVX392H
By BaggyB in forum DVD & Blu-ray PlayersReplies: 4Last Post: 25th Dec 2010, 11:50 -
Would You Increase the Upload Size Limit?
By Soopafresh in forum FeedbackReplies: 2Last Post: 12th Jan 2010, 15:23 -
Is There a Practical File Size Limit For Streaming FLV?
By phild in forum Newbie / General discussionsReplies: 1Last Post: 18th Aug 2008, 09:13 -
File Size Limit With TMPGEnc Plus 2.5 or MPEG-2?
By RABinMS in forum Video ConversionReplies: 5Last Post: 10th Feb 2008, 14:30 -
VDub/MOD cant limit my file size?!?!
By GangstaRap in forum Video ConversionReplies: 6Last Post: 29th May 2007, 04:36
