  1. I rip pearl harbor but how do I change to angle 2 thats where the movie is at. I am using dvd2avi and then Gknot is there a way to change to the second angle.
    Feb 2001
    Rhode Island, USA
    I've never used those apps, but you should use SmartRipper, because it will let you customize basically every aspect of the rip from any DVD.
    irc.webmaster.com port 6667 #DDR
  3. my friend let me borrow the movie so I dont have it no more, is there a program that can rip all the angles from the VOB right now.
