  1. Can someone suggest a switch box that would allow me to do the following:
    Input would be a composite video and audio cables running from a digital cable box.
    I want two different outputs selections that would run to my computer:
    selection 1. Composite Video and audio to my tv tuner card
    selectioin 2. audio to the line in on my sound card, with no video to the tv tuner card.
    I have discovered that Music channels from my cable box sound MUCH better when the audio is connected to the sound card, but I also need to have a selection where video and audio are both connected to the tuner card for when I do video capture (to prevent audio sync problems).
    What switch box would allow for this configuration??
  2. Preservationist davideck's Avatar
    Feb 2003
    USA
    A suitable audio Y-Cable should do fine. No need to switch...
  3. Why not just split audio from the cable box to go to both?
    Darryl
