I am trying to convert a divx movie to mpeg so i can directly burn it
The only way i see possible is through TMPGEnc...according to the "HOW TO CONVERT SECTION" in vcdhelp
anyway...i try to load up video source like it says in instructions...and this is what it says
File: "D:\VITE_DIVX_RH2.AVI", can not open or unsupported
This is the divx movie of Rush Hour 2 if you were wondering
Anyway...the movie plays fine
I am using DiVx Codec 4.01 if that might be causing the problem
Can anyone help me or tell some alternate method?
THANKS
Results 1 to 11 of 11
download the latest codec and that should help or you can do a brave thing you can uncommpress the Divx file to a regular avi file but that will take alot of space
where can i get the latest codec?
how to decompress the file...and how much space would a 700 meg file take up decompressed? -
you can get the latest codec http://www.divx.com
belive me it will take alot of space
_________________
To Get Faster Replys Email or Private Message Me
<font size=-1>[ This Message was edited by: pinoy2201 on 2001-12-22 13:03:24 ]</font> -
i installed the new codec 4.12 and tmpgenc still doesn't work...same error
anything else i can do? -
I think that you must have DIVx version 3.11 codec installed.
That did it for me, anyway.
<font size=-1>[ This Message was edited by: PhArAoH on 2001-12-22 16:18:03 ]</font> -
Uninstall Divx 4.
Download this http://doom9.org/Soft21/Files/divx_311alpha.exe
Run it. Don't register it yet.
Download this
http://doom9.org/Soft21/Files/DivX.Scene-Detect.Patch.v1.0.exe
Extract to C:\Program Files\DivX_311alpha (Yes overwrite existing files)
Then click on "Run Me First" in
Start Menu\Programs\DivX
MPEG-4 Video Codec
(or run Register_DivX.exe in C:\Program Files\DivX_311alpha)
Then re-install Divx 4, don't allow it to decode Divx 3 files.
Questi4110 you could still have codec 4.1 cuase they are made by diffrent companys you should have both just incase you download a movie file that was compress with the 4.xx edtion
Now, i noticed that the movie you tried to convert was Vites release, and kinda new one. Vites newest releases contain this .dll file you have to install, before you can watch movies, releases like Hardball, Hearts in Atlantis have this one with them. I didnt notice this first, i installed new divx codecs many MANY time , before I released whats wrong :O
Now, the problem is, that TMPenc doesnt support this new format :O
The movie is still .avi, but its not supported by TMPenc, and I dont know how to fix this problem ! So plz help me too!
TMPGEnc Authoring Works 4 problems...
By gonzalo76 in forum Authoring (DVD)Replies: 7Last Post: 12th Oct 2010, 02:59 -
Problems with TMPGEnc...
By SolsBBQ in forum Video ConversionReplies: 5Last Post: 3rd Jan 2009, 07:00 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 19:37 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 12:16 -
By maccool111 in forum ComputerReplies: 3Last Post: 23rd Jul 2007, 17:47
