I got an error saying "stream writing error" what do I do?
please put more details....deatils is the key to helping you,yes you out .......include details like when are you getting these errors and what progrma
I used TMPG Enc. I ripped the movie of a DVD and used DVD2AVI and then TMPG Enc. I made my own template, it's VCD, 352*240, 4:3 NTSC, 29.97 fps, birtrate-99999, VBV-0, 4:2:0, 10 bits, highest quality, progressive, field B, and 1:1 VGA. I got that error about 13% into the encoding process.
you can either delete the bad frames using VirtualDub, OR use a program called AVI2VCD. it doesn't have many options and it's slower, but it works this way.
DVD Architect Pro 5.2 error writing file?
By dabezt in forum Authoring (Blu-ray)Replies: 7Last Post: 30th Aug 2011, 08:55 -
ShowBiz DVD 2 Error - Failure writing the disc
By smbcingu in forum Authoring (DVD)Replies: 4Last Post: 2nd Jan 2011, 17:34 -
Error in writing a YUV frame
By krao in forum Newbie / General discussionsReplies: 11Last Post: 1st Sep 2009, 11:47 -
DVD writing error
By nathy85 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Nov 2007, 18:00 -
Error writing to media
By minepup in forum DVD & Blu-ray WritersReplies: 2Last Post: 21st Jul 2007, 08:28
