    When compressing a movie using DVD Shrink, is the bitrate changed as well? I know Shrink does Interframe as well as Intraframe analysis but I don't understand how or if this affects the overall bitrate.
  2. It would have to depending on dvd length and media size used.
    Quality is my policy.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    There's a thread at Doom9 that gives the "nuts n bolts" description of exactly how DVDShrink does its magic.
    EDIT:
    It might actually be at digital-digest. I can't remember exactly now.
    If in doubt, Google it.
  4. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Quite simply it has to. Aside from removing extras and alternate tracks, the only way to "shrink" a movie is to cut it shorter or lower the bitrate.
  5. This may help, first question, second paragraph of the answer.
    http://forum.doom9.org/showthread.php?&threadid=63587
    Pull! Bang! Darn!
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
  7. DVDShrink and all transcoders remove unneeded/repeated data from the GOP.
    Here's a decription from afterdawn.com:
    "Transcoding or more specifically Compressed-domain Transcoding means normally a re-encoding process that changes the video or audio features, such as resolution or bitrate, by changing parts of the a/v content, but not by reconstructing the content again (which is the case in encoding process). Compressed-domain transcoding also maintains the format of the file same as in the original file."
    Transcoding is sometimes confused with encoding.Encoding usually involves changing from one format to another(eg. AVI->MPEG).
    EDIT:you guys beat me to it.
