I am going to buy a JVC DVD recorder that allows you to record to a DVD-RW but not i am confused about which DVD-RW to buy? i wanted to know what is the difference between both these....
http://www.shop4tech.com/z/DVD_RW_2X_4.7GB/1_88_286
and this one...
http://www.shop4tech.com/z/DVD_RW_4.7GB/1_88_97/
can anyone give me any pointers on which one is the best to go with???
Quality is my policy.
2X is slow, 1X is twice as slow.
It really depends on what your recorder can use as far as the speed. You can look that up for your machine along with other media comments in 'DVD Recorders' to the left under user comments. <<<<
is it possible to feel the difference?
By FaisalKhan in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jan 2011, 06:17 -
Difference DV capture?
By Abas-Avara in forum Newbie / General discussionsReplies: 6Last Post: 28th Sep 2009, 15:17 -
What is the difference between these Taiyo's?
By ha13may in forum MediaReplies: 3Last Post: 27th Sep 2008, 15:01 -
HD-SD Time Difference?
By Nelson37 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2008, 21:13 -
Can YOU Tell the Difference ?
By Seeker47 in forum DVB / IPTVReplies: 14Last Post: 19th Nov 2007, 13:59
