I’m a newbie to all this, so bare with me. I’ve downloaded an ‘AVI’ video file and saved it to my desktop. When I go to open it, it asks which program I want to use, but I appeared not to have a compatible program. So I find this VideoHelp site, go to tools, download VLC Media Player, but still it won’t play.
I open VLC Media Player:
File > Open File > Browse > Locate File > Click OK ...but then nothing happens. What am I doing wrong?
Probably nothing. If Windows doesn't (try to) start Media Player, and VLC won't play it, I'm pretty sure you're not dealing with an AVI.
/Mats -
Could it be that you have the option "Hide extension of known file types" selected (it is, by default, in XP)?
Open any folder, select "Folder Options" under "Tools", then 2nd tab (Don't know what it says in your localization - "Show" or "Display" or something to that effect) then uncheck that option if it's checked.
/Mats -
Sounds to me as if there is a possibility that it is a virus(Trojan) especially if it came off of a P2P network. I hope I'm wrong and you haven't already infected your computer with a virus or spyware. One thing to try is use g-spot on it and see what it shows. one other thing is it could be defective.
Good Luck
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 07:28 -
AVI won't play. VLC say's doesn't support "IV50" Format. All codecs present
By Sikander in forum Software PlayingReplies: 2Last Post: 21st Feb 2010, 07:40 -
AVI files won't play in anything but VLC
By zanos in forum Newbie / General discussionsReplies: 6Last Post: 13th Dec 2009, 21:07 -
File created with sub2divx will not play on vlc or windows media player
By brattychiq in forum SubtitleReplies: 0Last Post: 23rd Jan 2009, 09:32 -
Media Player classic won't play any video...
By reapur in forum Software PlayingReplies: 4Last Post: 23rd Sep 2007, 02:49
