  1. A friend cannot play the RealPlayer clip here:
    http://64.27.98.24/clip.ram
    So, thinking I'd do him a favour while learning a little about basic conversion, I used R-click > Save Link As to save a file Ham1.ram on my HD, as in other circumstances that has downloaded the actual file. But of course in this instance it just downloads a 33 byte link
    To be honest, I didn't bother to check, and it wasn't until I'd run my freshly-installed trial version of EO Reader that I discovered my stupid mistake, i.e. on seeing this:
    "Error! This .ram file is script only which points to a distant internet server. (Err=30839 - 0)"
    Anyway, so what is the correct way of accomplishing this please? IOW, getting that short video into a format he can play in WMP9, which I do know he has working.
    Terry, West Sussex, UK
    You can try rm recorder.
  3. The RAM file is just a text file indicating the location of the actual file. Open it with Notepad and you'll see:
    rtsp://64.27.98.20:554/fordave.rm
    You'll still need an application that can handle the rstp protocol.
  4. Originally Posted by Baldrick
    Thanks, I'll try it. No freeware that does a similar job?
