Hi !
I created some SVCDs and also I do have some mpeg2
(SVCD-compliant) clips. Unfortunatly my new
DVD-standalone Player does not support SVCDs.
Now I decided to buy a DVD+RW drive to make DVDs.
How can i convert the clips on the SVCDs and the mpeg2
files which are still on my computer to DVD-compliant
clips???
THANKS IN ADVANCE
Med.
Results 1 to 9 of 9
Hi @ all!
I'm still searching for answers!!!
If I've overseen some "How To" topic you are
free to write me some 4-letter words BUT
AT LEAST tell me where to find the answers!!!
BIG THANKS TO ANYONE WITH A HINT!!!
Med. -
Look to the left -----> under WHAT IS...select the SVCD..go to the end of the page, follow the instructions listed.....the first time I tried to create I used these insturctions and came out right the very first time for both VCD and SVCD.....don't expect good results the first time, I have a box of costers....just keep trying....
Bud -
Hi !
Thanks Bud for your reply!
I DO KNOW the specifications of (S)VCD.
I DO KNOW how to make compliant mpeg1/2 files.
I DO KNOW how to author and burn a (S)VCD.
I DO NOT KNOW how to convert the SVCD compliant
AVSEQxx.mpg files to DVD compliant mpg files !!!!!
(SVCD -> DVD)
PLEASE HELP ME SOMEONE!!!!!!!!!
A kingdom and my daughter for the man with the
solution!!!
Med. -
If I were U I would put them on a dvd in SVCD format. DVD format will not make a svcd look better. just convert to 48hz audio and leave the bitrates.if u wanted u could change rez to 720 480.
Hi Stonecold420 !
What program do I need to convert audio from
44100 to 48000 and mpeg-video from 480*480 to
720*480???
Best greetings and my biggest THANKS!
Med. -
I would leave the res at 480x480. to convert the audio use tmpeg and load the sound of your movie only. than convert that,and use the mpeg tools in tmpeg to remux your new sound file with your video. If you wanted to you could try just leaving it alone. sound may play. Also you could use dvd2avi and rip your svcd disk. just look in the mpegavi dir on your cd. With the second method you can encode to whatever your new requeirments are. Just remember that you can't make your svcd into a better quality than original. If you try u will only waste dvd disk space
Hey, I will try this DVD2AVI thing to rip my own SVCD
I know that whatever bitrates I use to reencode my
SVCD clips won't look any better than they look on SVCD.
Are you sure that my Standalone-Player will be able to
read SVCD clips (with 48khz audio) on a DVD?!?
MY KINGDOM AND MY MOST BEAUTIFUL DAUGHTER ARE ON THE WAY
TO YOU STONECOLD420,
, THANKS VERY MUCH!!!!!
I can tell you that my philips dvd 711 will play audio at 48000 from any disk. IE:vcd svcd dvd or xsvcd xvcd. You could ask around about your player. I wanted to see how your progress was going.
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 10:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 11:05 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 21:44 -
How to burn a SVCD onto a DVD?
By php111 in forum Authoring (VCD/SVCD)Replies: 9Last Post: 16th Oct 2007, 03:32 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
