Running 10.3 on a G5. When converting a VOB with subtitle stream to H.264 video in a MP4 container, choosing the "burn" the subtitles to the final video an output error occurs. Under previous versions, using the same VOB file and settings and using the then experimental AVI/H.264, mencoder produces output where the subtitle consists of a very slightly translucent light border with a more translucent interior. If you choose to use the "Preview" option on the same filters pane, you still see this in the preview video. However, after actually burning the file, the interior of the text is solid black. This happens regardless of whether an IFO palette is provided (taking into consideration that an IFO palette was not previously required). While not unwatchable, this discrepancy between the preview and output, as well as with previous versions, seems undesirable. If you wish, I can produce some screen shots. Thanks for your hard work.
Results 1 to 1 of 1
mencoder x264 issues
By tommiy in forum Video ConversionReplies: 3Last Post: 19th Sep 2010, 03:14 -
[HELP] Mencoder Resize = No Subtitle
By randall87 in forum LinuxReplies: 3Last Post: 29th Jun 2010, 08:38 -
Ubuntu+mencoder+Pinacle dazzle capture issues
By mankeletor in forum LinuxReplies: 0Last Post: 21st Jun 2010, 09:33 -
avc2avi and mencoder issues
By tao63 in forum Video ConversionReplies: 1Last Post: 5th Feb 2010, 04:32 -
By tao63 in forum Video ConversionReplies: 1Last Post: 5th Feb 2010, 04:14
